Chances are you have an issue with a door switch or door switch mount, or most likely, a shorted cook relay.
See my help files here:
http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm
http://www.microwavecontrol.com/doorsw.htm
If you need further help, e-mail me through my Web site (above) with your full model number and detailed symptoms.
SOURCE: KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
SOURCE: Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
SOURCE: i have an emerson microwave model# mwg9111sl that
Yes, this is a major issue concerning the control board(control fault). replacing the control will fix this issue.
SOURCE: Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
SOURCE: Emerson Microwave Oven Model MWG9115SL: At
I suggest you check and/or replace the door interlock switches.
Hopr this helps.
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
If
the microwave runs for a few seconds and stops there may be a short
circuit in the main control board. Check other components first,
these boards are often misdiagnosed.
If
the microwave runs for a few seconds and stops the touchpad and
control panel might be defective. There are several other components
that can cause this problem, be sure to check any other components
before replacing this board.
If
the microwave runs for a few seconds and stops the touchpad might be
at fault. This is not common. Generally speaking, if the microwave
display is working and some of the buttons respond correctly but
some don't, the problem is with the touchpad.
If
the microwave runs for a few seconds and stops the high voltage
transformer might have an intermittent short. This is not common.
Check other components related to the microwave symptom first.
If
the microwave runs for a few seconds and stops the thermostat might
be defective. Watch our video on testing thermostat
