SOURCE: yamaha rx-v2500 receiver how to hook up speakers
You can hook the speaker like this one center speaker , two front right and left speaker,and then rear right and left speaker and one sub speaker in the unit ...
Good luck...
SOURCE: Yamaha DSP-A2070 intermittently fail to output audio to speakers
Probably selector switch when you turn to CD mode. The ball bearings inside the switch make poor connection resulting in intermitant problems to either speaker. Yamaha knows the selector switch is defective but has stayed silent. I've had mine replaced for $144.00 Can and it works AOK now. Different switch of course. I've had my problems with that switch for a long time and it was after a few years that a knowledgeable technician knew of the problem. Poor support by Yamaha! I'll never buy a Yamaha product again nor will my relatives and friends. Do the calculations and assess whether the cost of the switch is worth the value of the receiver. I think it is worth it as the receiver when it works is excellent. It is at a stage now when other problems could creep in though including corrosion on the boards and solder joints so have the technicians do a entire quality check at the same time...
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
were you able to solve this one ? I have the same problem with mine. The only way to clear the lack of sound in one of the speakers is to rotate the input knob !!
SOURCE: Sherwood RX-5502 receiver - get
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
