Televison & Video Logo
Dave Burgess Posted on Dec 09, 2018
Hi, I was playing(?) with my remote and have changed a setting that I can't change back I get a no signal and I know that there is one.
I should state that it is Sceptre that I am using and everything was working fine till I got my hands on it
5 Related Answers
Anonymous
  • Posted on Mar 18, 2009
SOURCE: I have a Panasonic combo
Hold down the "1" and the "Enter" buttons together for about 10 seconds. This worked for me.
Anonymous
  • Posted on Apr 03, 2009
SOURCE: Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Anonymous
  • 325 Answers
  • Posted on Sep 02, 2009
SOURCE: sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Anonymous
  • Posted on Nov 28, 2009
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Anonymous
  • Posted on Mar 31, 2010
SOURCE: Why did the TV remote input stop working?
It worked for me too. Thanks
6helpful
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
3answers
Change from PAL to NTSC
To begin, the first and second problems are completely unrelated.
If you bought a PAL TV and are playing an NTSC source, the result will be an invalid format. The two sources are not compatible. However, there are converters available, see: http://www.converters.tv/signals/ntsc_to_pal.html (just as an example).
To the second user. My first guess is that you need to select the proper input on your TV. Look for the "input" button on your TV remote and toggle through each input until you see a picture. The problem may be more complicated than that, but, to troubleshoot, I need to know: what TV you have, how many devices and what devices are hooked to the TV.
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
17answers
New play tv wont work via remote play on my psp
To make Play TV on the PSP via the Remote Play work
watch the instructional video here
and detailed information here in full-color
be aware that this whole thing depends on the firmware version of both PSP and PS3
Remote control
Hi Maria.
The States USA uses region 1. N.T.S.C.
You need a One for all universal remote control.
If you have 1 of these, contact me and i,ll give you the instructions on how to make the player multi-region.
Mike @ Compurepair.
2answers
Hitachi onscreen menu access
Afraid only the original remote will fix this. All universals and aftermarket remotes will not have the function you need. try going here www.vancebaldwin.com and use there remote finder and see if they have the one you need
4helpful
3answers
Change my LG DVD player to multizone
Thank you .. thank you..
I bought 4 dvd's from the states that wouldn't play in Australia changed the region and it is now playing
thank you so very much
3helpful
3answers
Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Top Sceptre Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
