Question about Samsung Audio Players & Recorders
My itrak soundbar won't play with my Samsung tv
4 Suggested Answers
SOURCE:
SOURCE: Cannot turn TV off when playing CD's with samsung HT-X810R/LG50PG
Problem traced to Samsung's Anynet+ System interacting with LG's Simplink. They seem to be
compatible. Cured by Menu/Option/Simplink/OFF. Hope this helps with anyone else having this problem. trev6.
Posted on Jan 10, 2009
  • 13 Answers
SOURCE: can you control the soundbar volume through a samsung tv remote and what type of cable is used to connect the soundbar to the tv
do u have red cable connect it to your tv and then to your settop box or what ever u have
Posted on Apr 26, 2013
  • 1662 Answers
SOURCE: The soundbar connected to my TV stopped working after I accidentally reset the remote. TV is Spectre X405BV and soundbar is a Samsung HW-K450/ZA.
By "reset the remote," did you mean you reset the TV to factory defaults? If so, you would need to reconfigure your sound settings.
Posted on Sep 28, 2018
Testimonial: "No Paul, The TV has the Option to reconfigure what the remote controls, i.e. does the remote control the volume on the TV or the soundbar."
Why does the soundbar play with Roku but no sound comes from the bar when on regular t.v.
You have to go into the audio set up screen on the TV and direct TV sound to the output cable connector you used for the sound bar. Example: Optical, digital.
Jan 01, 2016 | Samsung Refurbished 5003 Series - 40"...
My new remote for an itrak sound Bar model BT0218MO will not work at All? Can someone answer? Ty
iTraK Bluetooth Soundbar with Tuner and Remote, Black ...
www.sportsmansguide.com/.../itrak-bluetooth-sou...
The Sportsman's Guide
Rating: 2.7 - ‎3 reviews
iTraK Bluetooth Soundbar with Tuner and Remote, Black ... You can also wirelessly stream music from your Bluetooth-enabled smartphone or MP3 player to ...
iTrak - Electro Brand
Dec 25, 2015 | Televison & Video
I connect my I live soundbar to my Samsung plasma TV and I'm not getting no sound from the TV to soundbar please help
Check the TV's audio menu to make sure there will be signal available at the RCA outputs
Some sets won't allow both internal & external speakers/sound bar to both be on.
Jan 07, 2015 | Samsung Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
Hi, I have a hwh450 soundbar, I cannot get any volume to TVs, the tv is telefuken
Here is a link to your product description. When you get to the web page, click on the "Manual" tab to read the user's manual to find out how you can connect your soundbar to your TV.
HW H450 Wireless Audio Soundbar Samsung Home Audio
Jan 04, 2015 | Samsung 2.1 Dolby Digital Wireless...
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
I have an auvio 32 inch 100 watt soundbar with dock for i pod or i phone how do i hook it up to my 47 in phillips tv
You would input to the aux input on the sound bar from the line out on the tv if it has one. Save your ears and keep the levels low until all works.
Nov 07, 2014 | iTrak Encore 32" 2 Channel Bluetooth...
How do I connect an itrak soundbar model #bt0218m0 to a hitachi1080 tv model #na92172
Most HDTV's do not have an "Audio Out" connection, because they're usually not the thing producing the sound. You probably have a cable box and/or a DVD or blu-ray player, which is then plugged into the TV. You need to keep the video part of that plugged in, but unplug the audio and plug it into your soundbar instead. You will probably need some form of adapter, though I don't want to go into that too much without knowing what your setup is.
Nov 10, 2013 | iTrak Encore 32" 2 Channel Bluetooth...
Jan 08, 2009 | Sony DAV-S500 System
48 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
