Refrigerators Logo
J
John Decker Posted on Dec 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, how do I rest a Frigidaire fridge model LGHK2336TF? There is no option to reset on the control panel
Chris Huff
Level 3:
Top Expert:
  • Frigidaire Master 6,289 Answers
  • Posted on Dec 08, 2018
Chris Huff
Frigidaire Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019825
Points
74913
There is no reset button. You can try unplugging for 5 minutes to see if electronics will reset.
4 Related Answers
Anonymous
  • 105 Answers
  • Posted on Jan 27, 2008
SOURCE: Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
A
Anonymous
  • Posted on Mar 15, 2008
SOURCE: CONTROL PANEL ON DRYER
YES
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Jul 24, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
    You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
    emissionwiz
    Marvin
    • 85242 Answers
    • Posted on Sep 12, 2018
    SOURCE: I have GE fridge model gss23wstass. The power went out in the neighborhood now control panel won't light up. There is power to the fridge. Is there a reset?
    No reset, likely the surge when the power came back damaged the control panel, contact your local utility and file a damage claim
    Alarm fault Bush fridge freezer onBSBSFFSS model. Alarm going off continually. No obvious reason
    Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
    Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
    Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
    Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
    ·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
    Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
    Read more :
    http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
    http://www.appliancerepair.net/refrigerator-repair-1.html
    Maytag fridge bepping lights out MFI2568AES...fridge and freezer working..what could it be... Beeping all night long..
    Read more :
    Cause of Beeping Noise in Frigidaire Refrigerator eHow Refrigeration System Basics Chapter 1
    E240B Fridge Freezer door open alarm goes even when door closed.
    Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
    Fridge keeps bleeping
    Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
    http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
    Model E402b. Why is the alarm going off?
    Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
    Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
    Beeps about 6 times when fridge door is opened.
    Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
    MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
    Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
    2answers
    I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
    After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
    Thank you
    Top Frigidaire Refrigerators Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    john h
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
