Question about Samsung Audio Players & Recorders
I've connected my Denon AVR 587 to a Samsung UHD TV 6 series with a fiber otpic audio cable and have NO sound. Any suggestions? Do I need to change a setting on the AVR?
    Sergeant:
  • 205 Answers
You'll need to ensure that the optical output on the Denton is switched on.
Posted on Dec 08, 2018
Testimonial: "I've tried to change the input mode to PCM, DTS, Auto and nothing works."
SOURCE:
  • 14 Answers
SOURCE: sound issues Samsung series 6
The speakers that come with built into the units are very limited at best. Better than the old 4" speaker that came in TV sets from the old days, but not by much. Ask if you are not expecting more out of the output than is reasonable.
I would offer that the true design intent is to hook the HDTV into a home surround system, a home system is optimized for and designed for your listening pleasure. I'm guessing that your HDTV is an LCD with a sound bar at the bottom, if so it is for general use and not intended for critical listening.
I have a 61" Series 7 DLP and even with larger built in speakers, the difference is night and day between my surround sound system and the HDTV stand output.
john
Posted on Aug 20, 2008
  • 5 Answers
SOURCE: No sound on cable TV for Denon AVR 1905 Receiver
Audio setup on the TV, needs to be swited to Fixed or both, this is usually the same on all T.V.s....
Posted on Aug 25, 2008
issken
  • 1472 Answers
SOURCE: PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
Posted on Sep 29, 2008
  • 119 Answers
SOURCE: hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Posted on Feb 25, 2009
  • 119 Answers
SOURCE: Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
I have no sound on the avr-587 zone 2 when set to tv mode, but do get sound in zone 2 when using the tuner. What am I doing wrong?
You need to run an Analog (RCA) cable from your Cable Box, DSS, or FIOS to the Analog input of the receiver. It does not see digital signal input on secondary zones. Hope this helps
Jun 21, 2010 | Denon AVR-587
I am not able to get audio through my HDMI cables.
It's a monitor - no audio source capabilities.
Get TV-related audio from its original source, not the TV or monitor. TV's and monitors are NOT hi-end audio sources.
Cable box, DVD, BD, games: these are potential hi-fi digital audio sources.
May 25, 2010 | Denon AVR-3300 Receiver
I am trying to connect my new PS3 slim to my Denon AVR 590 and some odd reason I can't get any video signal from my Receiver... Something I am doing wrong?
Double check your inputs on the denon some are assignable, Check cables for looseness hdmi cables are prone to this since they are digital. make sure tv is on the right input and if it is try changing it to a different input "sometimes inputs/outputs go bad"
Feb 18, 2010 | Denon AVR-587
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
Hi denon to cable box to samsung lcd
Feb 25, 2009 | Denon AVR-5803 Receiver
Feb 08, 2009 | Denon AVR-587
How Do I Connect My Dell Laptop to a Demon AV Receiver
use a 1/8in stereo to two male RCA plug to connect from your computer headphone out to an input on the Denon such as AUX or CD
Jan 25, 2009 | Denon AVR-587
73 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
