Hi
Check there is no dust or dirt that is stopping the lens mechanism retracting the lens properly (which is then interfering with the cover closing). You should also try and check if the cover is aligned properly. If it has been dropped or knocked it can sometimes move them out of position and this can then stop them closing properly.
We hope this helps to get the camera working properly once more.
SOURCE: Lens Retraction
Since your camera should be still under warranty, best thing will be to conntact to the appropriate factory service center for correction of the problem. Good luck!
SOURCE: lens cover won't open
Here's a fix for a Canon A400 lens cover. See if it's applicable for you:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
SOURCE: Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
SOURCE: lens will not retract
In my case, there was dust in the switches that sense the cover movement.
