Tried all power resets and remote and tv power button also. The only voltage on any power board connector pins is the 5vdc standby at various pin location. Any advice would be appreciated. Thanks, JP
SOURCE: front panel connector
Hi Louis, The information you are looking for is on Intel's site at http://support.intel.com/support/motherboards/desktop/d845bg/sb/cs-013120.htm#8 Best Regards, Denis Rouleau
SOURCE: FAULTY POWER SUPPLY FOR LITE ON PS -5251-2DS
when connected the AC power , no DC voltage reading from the p.s.
what to do?
how can i turn it on?
SOURCE: How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
SOURCE: how to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
