Question about Jensen Televison & Video
Remote code for a Jensen TV. Setting up a Dish receiver
SOURCE:
SOURCE: JENSEN JER 323 REMOTE
i need the tv codes for the jensen jer 323 remote for a diamond tv
Posted on Feb 06, 2008
SOURCE: locateowners manual/program codes for tv remote
Codes for Zenith T.V are 1000,1001,1004,1083,1101,1100,1099,1097,1089,1078,1022,1020,1011,1009
Posted on Jan 14, 2009
VOTIT
  • 2071 Answers
SOURCE: need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Posted on Jan 28, 2009
SOURCE: samsung remote code for dish net. not working
Try 069, 070.
Pick your Mode, then Hit the set button at the bottom, then type in the numbers and you should see the mode light up 4 times if done correctly. Hit power and see if it goes on. I think the Frequency changed though.
Posted on May 14, 2009
whytfang
  • 170 Answers
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
Posted on May 20, 2009
Tip
DISH VIP612 Remote Code Scan
DISH Solo DVR VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Code for jensen tv
These are codes for Jensen: 0004 0009 0133
Nov 22, 2012 | DISH Network IR Remote Control
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need remote code for programming a bell expressvu receiver
JVC DVD 0558, 0623
Regards,
VOTIT
Jan 27, 2009 | Jensen 143307 Remote Control
Hitachi Plasma
i have dish network different brand tv but have codes for hitachi they are 1004,1006,1012,1013,1059,1060,1063,1135,1136,1145,1148,1179,1185. hope one of these helps
Dec 13, 2007 | Jensen JER-422 Universal Remote Control
Dish Network Remote Code?
My remote dosen't want to listen to me. The light dose show but it's not doing what i say. Whats the matter with my remote?
Sep 02, 2007 | Jensen TS2050J 20" TV
Televison & Video Logo
115 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
