SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
SOURCE: Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the "0000H" on the bottom left of screen...that's how mine worked today.
SOURCE: Lost the instructions need help setting it up for
Here ya go:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Testimonial: "great instructions, thanks"
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
SOURCE: I do not have operating
Instructions for DT300
Testimonial: "Thanks, The user instructions for my Intermatic 7-day Digital Timer ( Model DT300 Series) is just what I needed"
