Refrigerators Logo
J
Jim Stakaitis Posted on Dec 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a problem with Kitchenaid model KFIS27CXMS5. Water on floor intermittently, from freezer. Same as earlier problem, but different model. If so, where is the defrost drain is in this model?
Chris Huff
Level 3:
Top Expert:
  • KitchenAid Master 6,289 Answers
  • Posted on Dec 08, 2018
Chris Huff
KitchenAid Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017803
Points
74913
It’s above evaporator coils which are located behind removeable panel on inside back freezer wall.
5 Related Answers
Anonymous
  • Posted on Dec 31, 2008
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Anonymous
  • Posted on Apr 28, 2009
SOURCE: ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Sep 20, 2009
SOURCE: water leaking onto the floor from freezer drain...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. .
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Sep 26, 2009
SOURCE: How do I unclog defrost drain on a model TBX18W?
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Anonymous
  • 6784 Answers
  • Posted on Dec 13, 2009
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
2helpful
KitchenAid KSCS25FTSS02 intermittently leaking water onto floor
Is there a sheet of ice on floor of freezer? Sounds like a stopped up defrost drain.
Ice forming on bottom of freezer compartment under freezer baskets...then finding water on the floor. Frequency is once every few days...Fridge is a Kichenaid KFIS27CXMS5
The unit defrosts itself and the water runs down a tube into the drip pan under the base. There is a coil (condenser) that gets warm and helps to evaporate the water in the pan. These things get very dusty and gross. Remove the front kick panel and clean the drip pan, check the drain hose for obstruction all the way to the evaporator coil in the freezer and make sure the unit is level.
Water on floor of freezer
sounds like a colged daring line.
Kfcs22evms ice under freezer door and water leaks out onto floor
You may have a leaking door seal, check for gaps in the door seal.
I have a Kitchenaid Superba side-by-side refrigerator that is 14 years old. I noticed water on the floor tonight and the tray below the freezer was full of water. I emptied out the tray but water seems...
There is a hose that runs from under the evaporator coil inside the freezer (it is connected to the inside drain pan) to the outside to deposit the defrost water into the outside drain pan. That hose may be cracket, broken, or maybe when you put the outside pan back somehow the hose did not wind up above the pan so the water would go into the pan. Check the location of the pan. If you need more help, just write back.
Water leaking from inside freezer door onto floor model kssc48qks01
most likely the drain is stopped up and that is defrost your seeing
KitchenAid refrigerator(leveling screw problem)
Realized after studying the parts list (on kitchenaid.com) for the model that the screw I couldn't get back in is BROKEN . Repairman coming tomorrow. Maybe that is why the thing sits so low ...
Water leaking into the refrigerator
Hi, You have a drain plugged in the frezer. Your model # doesn't come up but what you need to do is remove the rear anel in the freezer and clear the ice. If the floor of the freezer has two screws holding it, remove it as well.
Please check the model# again and I can assist you further. There is an after market deat transfer strip you might need to add to prevent this from reaccuring.
Thanks
Vic
Metal like taste in water
install a inline water filter that they can change from time to time
there are several types of filters that can do different things some for odor or for minerals some for iron removal
if they have iron in the water that would be the first one to try
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
