SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
You can even now turn off your subwoofer / adjust the volume easily now!
SOURCE: Bose AM-500 Acoustimass Bass module hookup to new Sony STR-DG910 Receiver
it need it own sub out speaicl done so bye bose steyem crossovers wont work right in your set up nee dto upgrade the sub try mtx
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
SOURCE: Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Testimonial: "Got me on right path, but I'm still stuck."
SOURCE: I have a Lifestyle 35 and want to replace head
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
