SOURCE: hi
Sounds like worn brushes.. The motor would normally have to be removed for these to be replaced
Testimonial: "Quick concies reply thanks"
SOURCE: washing machine says door problem even though door
The door switch is no longer making contact internally or a wire has broken r disconnected. I would verify this with a test meter and replace the switch. Eric
SOURCE: hotpoint aquarius wmf 740 has error code f5 - what does it mean?
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
SOURCE: im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
