A tech looked at it, called GE and then told me I needed a new control board. I put in a new one. Same thing, no test mode. When I leave it alone for an hour, it comes on. As soon as a cycle begins, however, it shuts down, as if overheated.
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
SOURCE: Wont spin at end of any cycle
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
SOURCE: treadmill powers up begins to turn belt then shuts down
Have you tried to calibrate the speed. If not you might want to try it and see if it will help you with your issue.
SOURCE: Carrier weathermaker sx 58 furnace
I have serviced these furnaces for 20 years and I can tell you most of these models did not have diagnostic lite on them. (although some did, especially if the control board has been replaced) The problem is most likely a bad 3 wire pilot. This will cause exactly what you describe. 2 things to consider though. 1, If you were to replace the pilot don't get a cheaper knockoff. In my experience these do not last long at all. Get the right one from a carrier dealer. It will cost more but be much more reliable. 2 What is the condition of the secondary heat exchanger? Most if not all of the sx series had issues with the secondary heat exchangers rotting out and leaking. If the furnace is out of warranty you would be much better replacing the furnace as the cost of replacing the secondary heat exchanger will probably be almost the same as a new furnace. ( those babies are EXPENSIVE!)
