A very simple solution to r epairing all by yourself is getting help from handbo oks, they're very detailed and complete in every way so for me it was my best source to repair
one of the top sites for this is https://big-manuals.com/
SOURCE: hotpoint wf220 washing machine
most computer machines will do what your explaining , after the lights have flashed try selecting a prog, and press the start button
SOURCE: my washer is stuck on f/o5 with water sstill in
there is a blockage. to get the water out put the end of the drain hose into a basin lower than the machine. you may have to shake it about a bit to get the water flowing.
you will need to check the filter or pump for foreign objects.
these may be at the front behind the kick plate or the rear behind the lower panel.
SOURCE: keeps going on test cycle
Try the following, may work:
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
SOURCE: Hotpoint Ultima Super Silent WF865. I'm getting
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Testimonial: "Excellent, thanks for your help, problem solved."
