Garden Logo
A
Anonymous Posted on Dec 07, 2018
I have a STIHL BR600 BLOWER and the choke switch is loose and will not stay in the position set
kebingump
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 25, 2023
kebingump
Contributor
Level 1:
Answers
Questions
Helped
3789
Points
12
BR600, The choke knob is on carb. maybe knob is cracked if not carb is bad.
M Michael
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 22, 2022
M Michael
Contributor
Level 1:
Answers
Questions
0
Helped
2112
Points
Nobody on this page has the right answer
Nate Archibals
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Master 1,149 Answers
  • Posted on Dec 07, 2018
Nate Archibals
Master
Level 3:
Answers
1149
Questions
0
Helped
129459
Points
2514
A very simple solution to r epairing all by yourself is getting help from hand books, they're very detailed and complete in every way so for me it was my best source to repair
one of the top sites for this is https://big-manuals.com/
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jun 12, 2009
SOURCE: stihl ms170 keep running in off position
Remove the cover and on the multifunction switch there is a wire with a metal connector on it in the multifuntion switch that when in the off possition needs to make contact with the metal contact that is mounted to the houseing and extends to right above the multifuntion switch usually they get stuck under the switch instead of on top of it.
crazytony777
  • 257 Answers
  • Posted on Aug 12, 2009
SOURCE: Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Anonymous
  • 8 Answers
  • Posted on Aug 16, 2009
SOURCE: stihl weedeater FS100rx In which position is the
take off the air filter and look at the carb when you move the choke then you will know
Anonymous
  • 389 Answers
  • Posted on Sep 16, 2009
SOURCE: Stihl FS 55 will not start
After trying to start several times, remove the spark plug and see if it is "wet" If it is you are flooding it. Do not pull the rope more than 3 or 4 times with the choke closed, whether it "pops" or not open the choke half way after the 4th pull and make sure you have the throttle trigger squeezed to give it gas
barterjoe
Joseph Mueller
  • 346 Answers
  • Posted on Feb 26, 2011
SOURCE: need repair Manuel for Stihl br-550 blower
A shop like www.arcolawn.com can get you Stihl tools and parts.
It sounds like your carburetor is not meetering the fuel properly. A rebuild may work but the carburetors on many machines have fropped in half in the past 2 years.
You may have a bad seal on the crank shaft or an air leak somewhere. If you take it to a dealer most shops charge less than an hour time to perform a full check on the machine and you can do the work.
Good luck
STIHL BR 600 Magnum Low Emission Backpack Blower. How to check Stihl BR600 coil please?
Question edited for a lot more clarity. It is a 'Stihl', not a 'still'. Please always state FULL 'make model (what it is)'.
Question moved to model category.
The standard way to test any HT Ignition coil is as follows.
Remove the spark plug and ground it to the cylinder head.
Disconnect the positive lead.
Ground a 12 volt battery - (minus) to the cylinder head.
Touch a positive wire to the positive on the coil and release.
The plug should spark when you REMOVE the positive power.
Coils, leads and ignition modules
https://www.google.com/search?q=stihl+br600+coil
Videos
2answers
I am a 2 stroke technician an I am having a issue with a br600 stihl backpack blower. it runs great at high rpm but it will not idle when I get the idle set it idles down on its own a dies. Its under
the fuel filter is blocked up check inside the feed tank for a few leafs floating about and blockages
run the unit from a can of petrol to rule out a fuel feed issue
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 • Stihl BR600
Why does my leaf blower lack power
Could be worn plug,bad gas,dirty air filter.Don'y buy your plug from stihl,too high ,go to autozone.The filters you have to get from them,i use there oil mixture,
Stihl manuals free download
nope, nope, and nope. Stihl offers nothing for free and their manuals are all online and you have to have dealer credentials to access them
I need stihl BR600-Z parts diagram
had same model, I took my hose (piece) and old broke clamp to ACE and got everything to fix...Even put a new fuel filter hose into gas tank for $ 15.00 less than ordering from factory.
Gas cap leaks
the seal is missing youve dropped it in a garden somewhere
you need a new one
try ebay
but i will tell you stihl is VERY good at service parts
and very helpfull
http://www.ebay.co.uk/itm/PETROL-FUEL-TANK-CAP-FITS-STIHL-BR500-BR550-BR600-BLOWER-/141346840553?pt=UK_Home_Garden_GardenPowerTools_CA&hash=item20e8ed9fe9
Ignition module gap setting
look up the manual on the stihl site
it tells you this detail
Backpack blower runs on choke only
replace fuel filter
air filter
spark plug
and clean the carborator jets etc...
change/change out the oil and measure the amount you put in
by the manual info look on the sthil site for the manual
How to set the timing on sthil blower br600
you can only adjust the coil to flywheel gap... timing for the flywheel is preset and un-aqdjustable
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
