Question about Labtec Audio Players & Recorders
WHAT SIZE POWER ADAPTER FOR LABTEC SPIN 45 - Labtec Audio Players & Recorders
NEED TO REPLACE POWER SUPPLY
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
Nov 12, 2012 | Labtec LCS 150 Computer Speakers
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
No sound
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 04, 2010 | Labtec Spin 45 Computer Speakers
I just need to know the specs on an AC adapter for my old Labteck SS-100 speakers. I want to buy a generic AC Adapter at Radio Shack and they suggested that I contact Tech Support.
i do not see a reason of wastig money on that venture as these speakers were not that hot when first made, humming noise from them was most annoying "feature"... but...
labtec ad-4 adapter was used in them, and output was 6vdc, 400ma, plug was 5.5mm x 2.1 mm with negative centre, if i recall, there was compartment in them for 4 "d" size batteries as well.
if you find this advice helpful, please do not hesitate to leave your recommendation and vote for me, thanx!
Jul 31, 2010 | Labtec SS-100 Computer Speakers
No voice
Connect a headset with a microphone. Plug in Red jack in red connector in your CPU/ laptop and try. I wish your explain your problem with few more word. I just give you that much suggest. Because i don't know what's your " No Voice " problem & where.
Thanks.
Feb 04, 2010 | Labtec Spin 45 Computer Speakers
Laptop won't power up without battery, needs 135W adapter
The ASUS power adapter is below spec and it may damage the adapter because the HP is drawing 45 W more power than it can deliver and will cause it to overheat.
The 17" HP requires 18.5 or 19 volts depending upon the model of the HP laptop (check the power requirements on the label on the bottom of the laptop). If the ASUS adapter doesn't deliver this voltage, it most likely won't power up the HP laptop.
Use the power supply/adapter from the other 15" HP. If this HP's adapter has a voltage output of 19 volts and the 17" laptop requires 18.5 volts, don't worry a voltage difference of 0.5 volts, the only problem is whether the power plug will fit into the power socket of the 17" HP laptop.
Oct 28, 2009 | HP Pavilion zd7020US Notebook
The speaker volume is barely audible, even with the sound turned all the way up
Sorry to bug you, folks - I was able to solve this problem really easily, by rebooting the whole system (I'm on a SunRay Thin Client, not a PC).
Best regards, A.
Jun 23, 2009 | Labtec Spin 45 Computer Speakers
Labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
Feb 07, 2009 | Labtec Spin 70 Computer Speakers
Top Labtec Audio Players & Recorders Experts
Alun Cox
Tony Raia
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
