Steps for analog timers shown on following link
http://waterheatertimer.org/How-to-set-timers.html
SOURCE: How to send MMS through i-mate JAMA
mms is a gprs service,, u will have to ask your network provider (tmobile, vodafone,, whoever is urs) for mms settings.
SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
SOURCE: I purchased a lampmaster #38439 timer and I need
it shoudl have had instructions with it in the box
Find the arrow on the face and rotate the dial to the arrow to set the correct time. Then with a suitable instrument or long finger nails raise the divisions on the rotating wheell to the TURN OFF TIMES the ones left are thye intervals of actual live time. Each segment is 15 minutes so one down 1 up is 15 minutes of ;lighted time and so on for 24 hrs the wheel is divided into day and night time by color 12 hrs of darkness and 12 hours of daylight time
Please rate my help++++Thanks for using FIXYA
Testimonial: "Your solution worked. Thank you!"
SOURCE: I cannot set the timers for off and on. The
They're ALL Down when you get the timer.. It would be helpful for them to state that in the instruction. Instead they tell you to push the pins down to set. Bur they're already all down!
SOURCE: How do I set a Stanley timer product number 398465?
Stanley timers are usually made by Westinghouse.
Copy following link for Westinghouse timers, and other same-similar timers and possible manual or instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westinghouse
Add a comment and describe timer in detail for more assistance
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
