Please unplug the tv for 30 seconds before powering on the tv again. Also, please check that the "auto power off" features isn't on (Settings >> General >> Eco Solution >> Auto Power Off >> Select Off)
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
It's likely that the TV will require service since your troubleshooting steps didn't resolve the problem. If your TV is smaller than 30", you may carry it in to the retailer of purchase for repairs. Otherwise, service for your TV can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
ok this is what you do folks.... un-plug the tv from the power supply. once that is done hold the power button down on the side of the television for 30 seconds. this will release all electricity out of the tv.... then before you plug it back in hold the channel down vol up button along with the power button at the side on the tv this should reset the tv and it will start up automatically on video one. Select your source and scan for your cable channels again. If the problem is not solved then contact someone to come and clean the filter for the tv because it may be clogged along with this it can be the color wheel and may shut itself off like 3 times until it feels it is right.
