You would have to make one. Why not look for the one you lost? Presumably you didn't do it outside sitting on the grass? Or return it to Casio for Service.
Hold down the MODE button until the time starts flashing. Then use the buttons to cycle through the time, date, and so forth until you see 24hr. On that menu tap the buttons you use to change the setting to cycle it to 12hr.
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
this might help.
press and hold top right button to change to T1 or time 1.
press and hold top left button and u will see ' light on/off' on display.
press bottom left button to set chime.
press again watch will show 24hr/ 12hr and current time set on watch. 12hr/24hr should be blinking.
press top right button to change to preferred hour.
press bottom left button to navigate to hour, min,sec
use right buttons to select numbers.
For setting Time & Date... 1. Push "MODE" button three times (change Mode to TimeSet) Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->... 2. Flashing Second Number Digits 3. Push "RESET" to select... Second -> Minute -> Hour(12hr<->24hr) ->... Date -> Month -> Day of Week -> Second -> ....(repeat) 4. Use "START" to set each item...
For setting Alarm ON/OFF 1. Push "RESET" button then Push "START" same time... Alarm ON -> Alarm OFF -> ... (repeat)
hello,to switch back and forth from 12 to 24hrs.:
push and hold lap/reset button and push the mode button,
an (A) will appear meaning it's in the 12hr zone,no (A) means 24hr.mode.
