SOURCE: Ice maker
Hollow ice is a sign that the icemaker is not getting enough water.
You will want to make sure there is enough water coming to the fridge and any filters in the system are clean.
If you need help checking it, please post the complete model number from the fridge and I can help you more.
SOURCE: no ice being made. water
Well first of all you can check to see whether the ice maker has been turned off, Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat. Please reply if you need more help or information.......
Good Luck!!
Thanks
