SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
SOURCE: ''how to replace starter in 1993 jet ski''
Unbolt the electronics box (swing out of the way), take off the box mount plate, and remove the exhaust upper manifold and expansion chamber. This should give you good access to the starter.
SOURCE: i need to know what
Your battery part number is: GIX50LBS
You can find this battery at:
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=200364&store=Main&catId=&productId=p200364&leafCatId=&mmyId=3724
They are currently out of stock, but the battery is expected in soon.
Hope this helps.
SOURCE: 2003 ski doo wiring diagram
Here is a link to the Ski Doo wiring diagram find the pdf. file and you will be able to download it. Good Luck
SOURCE: Joining wires from motor in ski-doo
http://www.vintagesnow.com/Ski-Doo_files/1982_service_BT.pdf
Hope this helps
