Question about Polaroid Microwave Ovens
Polaroid 04011c tv was tuning itself off and on then shut off and shows no signs of power since.
Outlet cord is fine fuse is fine wall outlet is fine. My question is : is it most likely the power supply board or something else?
    Habit-Forming:
  • 101 Answers
It is power supply board only as no power indicator is operational.
Posted on Mar 05, 2019
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: Microwave oven shutdown by itself, outlet has power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is not there, Please reply back with your brand and model number so we can help you.
Posted on Oct 08, 2008
  • 234 Answers
SOURCE: when I plug my microwave into wall outlet sparks
Well, the breaker has trip,but the microwave must have a short in it.Go turn turn back on and don't plug the microwave back into it to see if everything works.
Posted on Mar 14, 2009
arjoon
  • 113 Answers
SOURCE: Our Maytag microwave died. The outlet has power.
you have to remove the cover, un-plug the power cord=
un-screw the screws located behind the unit and on the sides if any also under side if any, remove cover and you will locate the fuses and other components behind the key pad, also check slow blow or thermal fuse usually located on top of oven. NB: HIGH VOLTAGE COMPONENTS PROCEED WITH CAUTION!!!!!!!
Posted on Mar 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: GE JE1160 1100 Watts Microwave Oven seems to have
Hi and welcome to FixYa, I am Kelly
Often it is a simple part replacement. There are 4 parts that can usually cause this.
- The Fuse fails as a result of another component failure
- The most common failure is the power diode. You remove the chassis to gain access and then make sure you hold a screwdriver by the HANDLE and ground the large capacitor at least 3 times across the terminals. Then you can check the diode by using an ohm meter across the terminals. It should read continuity in one direction only. (reverse lead polarity) If it reads in both directions OR there is no continuity then the diode has failed.
- Next you test the high voltage capacitor by reversing the leads and watching each time for a jump in resistance then the meter returns to infinity. (Diode must be disconnected) No jump in resistance after reversing the test leads or constant resistance = bad capacitor.
- Lastly the Magnetron could have failed. You read resistance of the leads of the Magnetron with one lead disconnected. You must read resistance. No resistance = bad magnetron
I used model JE1160WD001 as an example since you did not include a complete model number. However, the parts I am referring to are common to all JE1160 models.
All parts except the fuse can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212857
The fuse should be a 15 Amp 125 VAC Slo-Blow Fuse. Available at any hardware or Appliance parts source.
A failed door interlock switch will cause the fuse to immediately fail if the micro-switch fails in the door open position.
This is a pretty simple microwave and you should be able to bring it back to life. Just keep in mind repair parts costs vs replacement if you have failed magnetron.
Thanks for choosing FixYa,
Kelly
Posted on Jan 22, 2011
MicrowaveSvc
  • 9156 Answers
SOURCE: I have GE Advantium 120 SCB1001 Microwave Oven. It is plugged in, outlet has power, but nothing comes on at all.
There are TCOs (thermal cutouts) which also can fail or blow, resulting in "no power" conditions.
All but one of them should be accessible without taking the oven from the wall.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The full service manual is here.
You can find helpful exploded views and order GE parts here.
BUT there is one TCO which has thinner wires of a color other than black or white. This is the hood TCO and should read "open" or "infinite" which is correct.
All other TCOs should read shorted or virtually zero ohms on a continuity test, as should the fuse.
The cavity TCO is only accessible by removing the oven from the wall, then taking off its outer cover.
When taking the oven from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jun 08, 2012
JWIN Model JK-777 won't power on. Checked wall outlet, no problems there. Does this unit have a replaceable fuse?
All microwaves have a main power fuse. You have to remove the outer cover. It will be located near the back by the power cord.
Nov 22, 2017 | Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Emerson mw9113ss wont turn on
    If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
    Nov 27, 2011 | Emerson Microwave Ovens
    No power to microwave
    Hello
    Check the Power Cord
    Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
    Switch the Outlet on
    Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
    Reset the Oven
    Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
    Check the Fuses and Breakers
    See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
    Oct 04, 2011 | Microwave Ovens
    The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
    go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
    Jun 21, 2011 | Microwave Ovens
    The cord become hot when it is in the outlet
    If the cord is hot you are pulling too much current to power the microwave oven. Make sure the microwave is plugged directly into the wall and not an extension cord or outlet strip.
    Aug 10, 2010 | Microwave Ovens
    Power quite one day it lost power like curcuit broke there is power to the outlet
    If there was a power outage, and then your microwave oven never came back on. Then it could be a possible fuse problem. If the circuit breaker had tripped, then after you turned off the cir. brkr. and turned it back on, then everything should've worked fine. Again, I would lean towards a blown fuse in your microwave. Now you're saying there's power to the outlet, and it still won't go on? Then my easy solution would be to plug it into another outlet, and try it again. Your problem could be that plug. After doing everything I just suggested, at any time did you get a digital readout on your time display in the upper right hand corner of the oven. Basically, is there any lights on at all when you're plugged into the wall. If not, then the problem is in the microwave itself! It could be just as simple as a blown fuse, but I would like you to try these other alternatives first. Feel free to contact me again if these don't work. Good Luck, and I hope I've helped you some. Let me know, Jim
    Apr 06, 2010 | General Electric Microwave Oven
    The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
    Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
    Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
    Beyond these tips, you may need professional help with this.
    Thanks for your interest in FixYa.com
    Jan 22, 2010 | LG LMV1630ST Microwave Oven
    Ge microwave model #JVM1540SM1SS
    Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
    Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    54 people viewed this question
    Top Polaroid Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Polaroid Microwave Oven Expert? Answer questions, earn points and help others
