SOURCE: Incoming calls sound only on reception desk.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Testimonial: "Great! Very specific and easy to follow instructions. Thanks for your fast response. RO"
SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
SOURCE: My panasonic kx-7731 phone only
A TA-824 comes with 4 manuals. One of them is the Programming Manual (PM) http://www.public.carl.airpost.net/Pana/TA-824/300_TA_PM_07-04.pdf and in it there is a description of how to program the system and set up incoming ringing in system programs 408-410 (pdf page 40)
Carl
SOURCE: NEC Dterm80 phone, Model DTH-16D-2.
You can change these settings by logging into the phone's ip address from the computer that is connected to the same network.
You can also try to enter into the menu of the phone directly from the interface and look for these settings..
SOURCE: How do I set the extensions for the nightbell function on the KX-DT343?
Ringing is controlled by an ICD group. You can do it from the control phone, but I wouldn't. Better to call your installer/dealer/service tech and have them do it. In programming from the console it's program 620 and 621 IIRC (that or 621 and 622)
Carl
