SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
SOURCE: Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
SOURCE: Washer is not draining. How do I remove the front
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Testimonial: "Thanks so much, really appreciate the quick response!"
