Many owners of the Bosch dishwashers perceive h01 (h: 01) or h02 (h: 02) and other signs as an error. But in fact, this is not an error, and you accidentally got into the start-up timer menu (delayed start of washing dishes). In this case, h01 means that washing dishes will start exactly in 1 hour; if the display shows h02, then washing process will begin exactly in 2 hours. As a rule, in most models of dishwashers from Bosch, a delayed start can be set in the range from 1 to 24 hours.
Timer programming
You can delay the start of the program in 1-hour steps up to 24 hours.
Close the door.
Switch on ON/OFF switch [1].
Press button [4] + until the digital display [9] jumps to h:01
Press [4] + or - button until the displayed time corresponds with your requirements.
Press START button [6], timer programming is activated.
To delete timer programming, press the [4] + or - button until h:00 is indicated on the digital display [9].
You can change your program selection at any time until the program starts.
It would help to know the model number to determine the features of your dishwasher. The only guess I can make is that someone pushed the "delay" button and you are now set for a 5 hour delay for starting the dishwasher. Pressing the Delay button a few more times should bring it back to Zero delay.
Push and hold the reset button on the bottom right of the watch and then push the mode button on the bottom left. When you push the mode button, all the days of thge week should no longer be illuminated. This is the same to turn the beep on, only you need to see the days of the week on not off.
I have experienced the same thing a number of times. To solve, open the door, then turn the knob, and push the start button on and off, and push the delayed start button (3, 6, 12 hour). Then close the door, and retry. This routine seems to reset the system.
