Https://www.amazon.com/Maytag-Refrigerator-Control-Board-12868513/dp/B002ZNE5HY
https://www.google.co.in/search?q=Maytag+refridgerator+how+to+reprogram+a+control+board+on+a+maytag+model+mbf22581xeq1&rlz=1C1KMOH_enIN790IN790&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwjyh9D4uoXfAhVMDiwKHR3qBsUQsAR6BAgBEAE
SOURCE: maytag mbf2258hew replace jazz board
bug, the jazz board is pretty easy to replace. The light cover will slide off toward the back. Now if you look behind the control panel you will see two slots. Take a flat blade screw driver and push the cover tabs in while pulling down on the cover. The cover will come down. Two slats slide in on the front and will release, disconnect the harnesses and install the new board. Reverse the process. Catriver.
SOURCE: I need to locate the serial number on my Maytag MSD2142AR
open door and should be on the left wall...
SOURCE: I have a 1999 Maytag Plus side by side
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
If the ice is on the floor of the freezer
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
OR
If the ice is on the back of the freezer
The evaporator coil behind the cover on the back
wall inside the freezer will ice up under normal conditions. Every 8 to 10
hours for around 20 minutes the defrost timer (or in most newer models the electronic
adaptive defrost control) will turn the defrost heater on to
melt the built up ice. There is a defrost thermostat which prevents the heater from
overheating the freezer by breaking the heater circuit when the temp reaches
close to 32 degrees F. The entire cooling system shuts off during the defrost
cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to
build up until the air can’t flow over the coil to circulate the cold air
through the freezer and into the fridge. The temperature change in the fridge
is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from
coming on OR it won’t turn the heater off when it gets too warm. It is clamped
to the evaporator coil at the top to sense the temp. If it appears to be
misshapen it is bad.
With an ohm meter it should show continuity when
cold and none when warm.
You can also bypass the thermostat to see if the
heater comes on then. If it does then you know the thermostat is bad and needs
replaced.
The defrost heater is
located on the evaporator. It is in a tube which is at the bottom and can also
go up the sides of the evaporator. On some types you can see a burnt spot if
it’s bad. With an ohm meter it should show continuity from end to end when
disconnected from the wiring in the freezer. You can also test the wiring for
voltage when it’s in the defrost mode.
If
you have a defrost
timer you
can test it. It can be located under the fridge behind the kick panel on the
front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts
down. The heater should now come on. If it does, replace the timer because that
means the timer is not running. If it
doesn't, check the heater and defrost thermostat. Turn the timer again till
everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer,
replace it if the heater and thermostat test good. It is located in the fridge
with the controls in some models and on the back in others.
SOURCE: Water leaking and freezing at bottom of freezer in
Clean the drain pan and drain line in the back of the freezer section
underneath the evaporator coil. (hint: use turkey baster with hot water)
Make sure water drains when you
pour it in. If it doesn't - also clean drain tube on the back of the
unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First
Choice Appliance
SOURCE: Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
