SOURCE: error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
SOURCE: Err7 in haier wahing machine
HOW TO FIX ERROR 7 PROBLEM!
This problem is quite common on these machines, especially just after the machine has been moved. As a previous poster has said, Err 7 is a motor error. It is usually because the electrical connector has become detatched from the motor. Here is how to fix it.
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
SOURCE: Haier Washer/Dryer HWD1000 water leak from the
Check the button trap. Little door at front bottom right corner. There is a big screw in plug that has to be closed very tightly. Also check the plug gasket is clean.
SOURCE: Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
