SOURCE: 2001 Honda accord trunk latch spring fell out
It probably goes on the outside of the casing One end arond the cable to hold the latch against the cable
SOURCE: how do i put the
Remove all bolts holding the rails to the body of the gun (make note of the position of the parts as you take then off ). Slide out the pusher assmbly. If the spring is good (wound tightly and has the bolt hole), hold the pusher assmbly in hand and attach spring to body of gun leaving bolt loose. Slide the pusher back into the rails and attach rails to body of gun up against the bolt (snug down bolt and check spring action). Re-attach rails to gun. Some after market rails do not have the slot cut into front allowing easy install of spring (cut slot with dremel). Good luck
