SOURCE: portable generator low voltage
85 volts represents residual voltage. It is possible that your unit sat for an extended period and lost it's magnetism or the excitation system failed under load. check your manual for a procedure to "flash the field". If that is not successful, e-mail me and I'll tell you how to trouble shoot the failure.
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
SOURCE: My admiral dryer LNC7753A71 just
Your dryer is equipped with a thermal fuse located behind the drum seat on the heating coil.
http://www.applianceaid.com/la-1053.html
There are two white wires connected to the fuse. Pull those off and connect together. Your door light will come on if that is your problem. There might have been a problem that caused the fuse to blow. Check for kinked dryer hoses, dirty lint traps or anything that might have caused it to overheat. You must replace the fuse or you risk catching the dryer on fire.
SOURCE: Honda EMS 4500 Generator - High Voltage Problem
As far as I can tell on the wiring diagram for this generator there is no voltage regulator unless it's incorporated with the auto throttle unit.
To lower the voltage you need to lower the speed of the generator engine. To do this there should be a screw on top of the engine under the tank when your facing the recoil. This screw presses on a arm that controls your governor. Turning it in (righty tighty) will increase rpms, turning it out will lower them. You should see the voltage change on the voltmeter.
SOURCE: GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
