See if red or blue, blue is cold red hot bad water solenoid
SOURCE: GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
SOURCE: washing machine leaking at the connection to water pipe.
Hi vks1,
Your water is coming out into the washer even when you water supply is switched off at the pipe?
Disconnect the washer hose from the water pipe and see if the water
still comes out of the water pipe even when the water valve is shut off!
If the answer is YES!
This is a plumbing malfunction.
The valve on your water pipe is not closing completely!
There is a washer in the water valve attached to the end of the valve stem that more than likely needs replacement.
And not a washer malfunction.
If I understand your explanation correctly this is the cause.
If this is not the problem then the washer has a water inlet that is stuck open.
But this dose not make sense if the external water valve is shut off there should not be water reaching the washer inlet faulty or not!
I believe I figured out the problem for you and you will be fine when the valve is fixed or the valve stem replaced!
Bless You,
ngafm
Let me know that you have succeeded!
Happy to of helped you.
Please give me a good rating before you sign off our site!
Thank You
SOURCE: Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
SOURCE: bosch fridge leaking water
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I have the same problem,warranty just ran out but its been
leaking on and off for ages,must be this model.This much Ive figured out,what
happens is the drain hole gets blocked from ice freezing over the hole at the
back of freezer, the drain water has to go somewhere, since it cant leak out of
the drain hole where it suppose to it ends up pooling under the vege
compartment before ending up on the kitchen floor.Now if this is your only
problem,someone suggested to me to run a piece of copper wire from the
defrost heater to the drain hole so no ice can build up there,hence no more
leakage.To do this you'll have to take the back panel off and see for
yourself,I did this and Im a novice.Make sure you turn off and unplug the
fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the
refrigeration compartment wont cool anymore but the freezer part remains
working as usual.Ive nailed this down to one of the following not working...
Thermostat / timer / defrost heater.So one or more of these needs replacing.Im
just trying to look for a manual which shows the nuts and bolts or the
refrigerator (not the "How to use" type manual which I have).
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
