No PC stated (sad no?) 10,000 models too for 20 + years.
I guess you mean 100% recovery windows to day1. that reset.?
there can be no answer lacking that key FACT.
but if lucky, and you find your manual. on your unstated PC
at Lenovo,
read the chapter on RECOVERY,
each generation of PC is done a different way.
NO PC no way to answer correctly , RTM.
here they are, official maker, not spam , REAL
go there and read first.
https://support.lenovo.com/us/en/solutions/find-product-name
Copy and paste
lenovo pc reset to factory settings
answer took about 5 seconds. You can search by youself
https://www.youtube.com/watch?v=geloFBkJWXs
Amazing how some can't even google.
for the recover to work the hDD must be good
and most PCs this old fail.
but NO PC stated.
nor will that work going to lenovo , not telling what PC they have.
steves answer only works on new PCs.
op never told what PC so no answers possible but one, gee RTM , read YOUR manual.
read the chapter, called, RECOVERY,
it will not lie to you if the manual is for YOUR pC of the 1000s of models made. for 20 years.
SOURCE: reset factory password on t61 lenovo
Pulling the bios battery does not work on the Lenovos - youll be wasting your time. Where did you get that information Jadestar - Ill bet you can't name one person for whom your solution works on these laptops!!???
SOURCE: factory reset for lenovo t410
if it is a newer model computer, 1 to 2.5 years old,there is an option in your Control panel setting to allow you to do that easily. or u tuibe may have a video of step by step to change the setting back
SOURCE: How do i reset my lenovo t410 to factory settings?
Read the manual and it will tell you the process. Get online
and got to www.google.com In the google search box type: "IBM
Support" or "Lenovo" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals and search them for Factory Restore or System Recovery. Why not consider another option?
System Restore will allow you to select a Restore Point
(date and time) to set your system back to when it was working ok. It
does not delete any of your data, documents, music, pictures, videos or
programs (unless the program was installed after the Restore Date you
selected).
System Recovery (sometimes referred to as Factory Restore) will set your system
back to when you first purchased it. It Deletes Everything. Most
times the System Recovery does not work unless there is a recovery partition on
your hard drive created by the manufacturer. If you are trying to recover
from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall
Windows. Look on your computer for the Certificate of Authentication
(COA) Sticker. It will tell you what operating system is on your computer
and it will give you the Product Key Code (a series of 5 letters and numbers)
that you will need to activate windows. If you don't have an operating
system disk, borrow one from a neighbor, friend, relative or co-worker. Just
make sure it is the same as your COA Sticker's operating system or it will
never activate. Also make sure you get the COA Product Key Code for the
disk you borrow because sometimes the system will ask for the one that is on
your system and sometimes it will ask for the one from the installation disk.
If your Lenovo desktop is pre-installed with Windows operational system, press one-key reset key when your laptop is power off. Or press Shift + B to come back to factory setting instantly when Lenovo desktop is open.
Or press F2 when your Lenovo desktop is powering on. Few seconds later, a dialog pops up with several options, one-key reset and reset factory setting. Follow the operation wizard to reset factory setting is OK.
Related topic:
Hi Gary Oakland, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
read the page marked, RECOVERY.
NO PC stated at all just Lenovo.
there vast models. post the full model name and number, and we send you to manual book. pdf
or go to lenovo.com
read your manual there, even download it
talks like 5 minute work to do all that.
