SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
SOURCE: Beko DE3762FW dishwasher starts but will not
Here is a tip that will hjelp you with your problem...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
SOURCE: washer wont drain. fills
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: Whirlpool Cabrio he washer stopped
You
may perform an automatic diagnostic test to check the machine functions and view any saved fault codes.
Fault codes may also appear during the test when a problem is detected. Be
sure the washer is in standby mode (plugged in with all indicators off,
or with only the Clothes Clean or Done indicator on). Select any one
button (except POWER, START, and STOP) and follow the steps below, using
the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You
don't have to accept or reject this post in order to add comment or
information. But accepting the solution
should you find it helpful and/or informative will not stop you from
posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
SOURCE: won,t drain on rinse cycle
I had this same problem. I replaced the computer and the relay boards without luck. I found it was the FILL VALVES! Apparently when the washer changes cycles it expects water to fill the tub to a certain level. If the valves are not opening and water not filling the tub will cause the computer to just wait and wait and wait and wont advance to the next cycle.
