I believe that model number is wrong......You must be referring to a Canon IR 2200 or maybe a Canon IR 2220. The Fuser has a problem when warming up. Replace the fuser or the Fixing film assembly and then the error must be reset in service mode.
SOURCE: How can i resolve the error code of E002-0000 on IR 2202? when ...
E002-0000
The temperature of the fixing film is as follows:
has exceeded 100C, but does not reach 115C within 1 sec thereafter. has exceeded 140C, but does not reach 150C within 1 sec thereafter. has exceeded 160C, but does not reach 165C within 1 sec thereafter
The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
1. State Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate? NO: See "The fixing heater fails to operate." 2. Wiring Is the wiring from the DC controller PCB to the fixing film unit normal? NO: Correct the wiring. 3. Fixing film unit, DC controller PCB Try replacing the fixing film unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
SOURCE: How do i solve an error e000-0000 canon ir 2202
Canon iR2202
Hi
Please follow the below procedure to enter Service Mode
1. In standby mode, press the "Settings/Registration" key.
2. Press the "Reset" key.
3. Press the "Back" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
COPIER> FUNCTION> CLEAR> ERR; and then turn OFF and then ON the power.
SOURCE: How to solve error e010 on canon ir 2202 copier
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
