Garden Logo
J
John Cooper Posted on Dec 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda em5000sx only runs with choke on. It runs rough with black smoke coming out of exhaust. Cleaned carb with carb cleaner. Can gas cap vent be a problem or is it just adjustment?
john h
Level 3:
Top Expert:
  • Honda Master 29,492 Answers
  • Posted on Dec 03, 2018
john h
Honda Master
Level 3:
Top Expert:
Answers
29492
Questions
0
Helped
7547064
Points
193431
Sounds like still a carb problem probably need to rebuild
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Jul 12, 2009
SOURCE: carburator is getting to much gas there is no
there should be one adjustment scew there
Anonymous
  • 130 Answers
  • Posted on Jul 18, 2009
SOURCE: Ryobi 725 R runs only when choked, full throtle
you will have to rebuild carb.red and yellow caps just pull off you might have to get a tool to ajust carb and take them out
fmdsaab
  • 157 Answers
  • Posted on Nov 24, 2009
SOURCE: I have a 1983 toyota pickup truck.the truck has
possible check vacume hoses if its hookup properlly
Anonymous
  • 148 Answers
  • Posted on Aug 03, 2011
SOURCE: 98 honda shadow 750 hesitates
Hi,,it is a fuel problem(lack of) as it runs better with the choke...make sure the pilot jets are clean and check your float level.
wadingriver
wadingriver
  • 2248 Answers
  • Posted on Aug 08, 2012
SOURCE: Engine only runs with choke on. Blue smoke comes out and engine runs rough or not at all
sounds like you have a bad Ring on the Piston or a blown head possibly. Blue smoke means Oil is getting into the combustion chamber. Full choke means you have to give this 'broken' engine a lot of gas to compensate for it's problem.
Do you change the oil at least once a year? Filthy oil or a lack of oil will kill an engine
1helpful
I need help with my B/S Engine. Lack of power and black smoke coming from the exhaust.
If the plugs are ok and your engine is not smoking after starting and running ..Sounds like either of three things..all with the carburetor .First the carb has a adjustment screw for air/gas mixture on the side if the carb where it attaches to the engine..try this start the engine and at about half throttle..now adjust the screw clockwise until the engine starts to miss and bogg down then back the other way until it starts missing and bogging again. Then slowly adjust back and forth until you hear the engine run the smoothest..give it more throttle if it starts to run rough do the same procedure until you get the results you want..if it is the mixture problem this will take care of it..if this doesn't it it may be your fuel jet in the bowl dirty or the blow float sticking..if you are not familiar with carbs best to have a professional look at it..you can drop the bowl by removing the bottom bowl and clean it out...check to see if the float easly moves up and down..replace the bowl and go from there..worse scenario new or rebuilt carb...good luck..
Rough idling & smoke comes out of exhaust
check to see if the choke cable comes in contact with any linkage on gear selector sounds like a choke issue
Jan 21, 2014 • Garden
Motor will start on choke setting and then it immediately dies when moving the choke lever to the run position. Cleaned carb, new plug new air cleaner and checked all linkages. the motor has new oil and...
You say you cleaned the carb. If you did that by spraying cleaner in through the choke, that's good, but it doesn't get to the root of the problem. The problem is getting the gas into the carb. Try this. drain the gas. Put a small amount of carb cleaner and gas in the tank (about 1:1) Start it up, but don't run it dry. Let it sit for an hour. Then start it up and run the tank dry. Then try just a little gas to see if that fixed it. If not, repeat. Good luck Al K
Em 5000sx runs but stalls under load. had a hard time starting have to play with choke. drained gas cleaned carb finally got to run. now when i plug something in it stalls under load
GX340 engine always works best with complete carb kit that at least contains main jet, needle valve, main nozzle and orings. It is hard to clean varnish/crud from carb and soaking may make it worse. Kit is not expensive. Check ebay, less than $10. Before you change any parts make sure that your cap is venting properly. Many California gas caps (tall chrome gas cap) may cause fuel lock. Also check that muffler is not restricted with carbon. Good luck
Greetings... My son's crf150f was running rough yesterday [backfiring-wouldn't rev smoothly] with choke in normal "off" position. Setting choke to half choke middle position allowed much smoother...
sometimes they are stubborne,I use stranded electrical wire to send through jets,just make sure when blowing into an orfus that it comes out somewhere hope this helps
2helpful
Kohler magnum 18 engine starts cold fine. the longer it runs the more choke is necessary to keep running. eventually when hot it wants to stall. also when going downhill it wants to stall. changed fuel...
01 Sounds like it is running out of fuel because it wants you to choke it to get more fuel.
02 Might have a restriction in a fuel line. Disconnect at carb and see if there is a good flow of fuel.
03 Loosen the fuel tank cap and see if the same thing happens. Cap might not be venting.
04 Any black smoke from muffler?
Apr 15, 2010 • Garden
Starts but runs rough, wants to run only with choke on
Sounds like your Carb needs to be cleaned. The easiest way to do that is to remove the fuel lines attached to the carb (note where they go first). Then pull the plastic caps off the the carb adjustment screws (discard if you'd like). Then turn the screws clockwise while counting the number of full turns (that way you can put them back at the factory settings). Take both screws out. Then take a can of carb cleaner and spray into each hole along with the inlet of the carb (this is where the air comes into the carb). Also while you are there you may as well clean the filter with soap and water.
3answers
Spark plugs are being replaces every 3 or 4 mowing
the carb is located under the aircleaner it sounds like the mower is being fan at full throttle this on some mowers applies the choke try ajusting the throttle to full then slightly back to open choke.
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
