SOURCE: confused
Hi jimmyjames, How do you have the wires hooked from the sony reciever to the inputs on the mtx? Sounds like your Remote wire is way too big. it should be 14 guage. It only sends a low voltage low amp signal. Another thing that could be messing up the sounds is the routing of the wires. you should have the power supply wires separate from the Audiop signal wiring. Power should run down the Driver side and Audio down the passenger side. When you answer I may be able to tell you more.
SOURCE: Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
SOURCE: need speaker wiring diagram for DEH-15 pioneer cd player
left front +white,-white/black
right front +grey,-grey/black
left rear +green,-green/black
right rear +purple,-purple/black
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
i have 2.1 channel speaker set it was not working what is the solution
SOURCE: Subwoofer Box for four lanzar 15"
I have been building custom enclosures since 1984. First of all I would need to know exactly what type of vehicle you were trying to install the enclosure into. You will need 8-10 cubic feet for this totally closure. I'm not too sure if you have enough room for this if it's going sometimes of small s_u_v you definitely have the room. I would use a 4 inch by pennington lane ports 1 in eating closure but you might even think about making to sebring closures and bringing them together because you're going to have a lot to flexing with that money into of what first. There again I need to know how much power you're driving to them as well and in what type of configuration you'll be connecting them. Good luck and hit me back up with any questions I will be glad to help thank you.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
