I think the best idea would be to back up your photos to Microsoft Onedrive. You can then view and copy your photos to the Ipad using the Onedrive app. I looked and there is a Onedrive app for the ipad. You could also back up your pictures to a computer and then copy them to the ipad using Itunes. I think the Onedrive route would be easier.
SOURCE: How do I transfer photos from my computer to my iPad?
When you connect your ipad to computer Itunes must be recognized it .
Make sure itunes version 9.1 installed.
If not then download from this link click here
Make sure ipad is enough charged.Try different usb ports.Makes ure usb cable is working fine.
Uninstall usb drivers from computer then check.For that press windows key +R so you can see run type in run "devmgmt.msc" then press enter.
Then you can see device manger uninstall all usb drivers 1 by 1 then it automatic install usb drivers.
restart iPad, first turn iPad off by pressing and holding the
Sleep/Wake button until a red slider appears. Slide your finger across
the slider and iPad will turn off after a few moments.Next, turn iPad on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is
iPad not responding? To reset iPad, press and hold the Sleep/Wake
button and the Home button at the same time for at least 10 seconds,
Then check then you can sync it with itunes in computer.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: transfere photo from laptop to apple ipad
To transfer photo from laptop to iPad, follow this steps.
1. In the iPad management screen, click the "Photos" tab at the top.
2. Check the "Sync Photos" box at the top.
3. From the drop-down menu next to that, select the program or folder that contains your photo library.
4. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so keep that in mind as you select between syncing all photos and individual albums and videos.
SOURCE: hi how do you delete pics transferred into ipad?
AnyTrans is an iOS content manager that allows you to transfer and manage your iPad, iPhone or iPod content. And you can also use it to delete selected or all photos from your iPad.
If iTune is helpless, you can try email the photos to your iPad. If you have lots of photos to transfer, this way might be slow and time consuming. So you can try an iPad photo transfer. This guide helps a lot. How to Download Photos from Computer to iPad
