Hi, check all the switches on the face panel, if the switches donot have a "click" feel when pressed then they are faulty.The face panel then needs internal repairs. Also check the gold connections behind the face. Check to see if all the contact pins are clean and shiny, and the same goes for the contact pins on the head unit side as well. cheers.
SOURCE: sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
SOURCE: Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
SOURCE: need a wiring diagram to install cd player
If you buy a wiring harness from
this guy he will send you a wiring diagram. Copy and paste the web address.
Here
you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
SOURCE: sony cdx-t69 CD Changer Unit
Bought a toyota with sony cd changer and had magazine stuck. Disconnected the cables at the back and left for 5 min. Hooked it back up switched to acc and pressed the eject button and came straight out. Didnt need to reset radio and retune.Now works fine.
