Question about Karcher Garden
My new karcher window vac is not heating up why?
3 Suggested Answers
SOURCE:
emissionwiz
  • 84581 Answers
SOURCE: No suction on my Karcher window wv2 vac
Check the hoses for clogs due carpet fibers.
Posted on Jun 08, 2018
  • 3307 Answers
SOURCE: karcher window vac doesnt start. when on button pressed, single red light appears
Should be green...
Charge or replace your battery.
Carnac the Magnificent
Posted on Sep 06, 2018
Jun 08, 2018 | Karcher Vacuums
My faulty Karcher window vac
so notify karcher or place where bought for warranty work
Aug 17, 2017 | Washing Machines
My karcher window vac charges but does not switch on.
Could be a defective switch, or it is locked because a threshold is reached, like reservoir is full.
But check while it is charging, because the manual says:
Oct 01, 2014 | Garden
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
Aug 02, 2014 | Karcher WV50 Window Vacuum
My karcher window vac does not seem to charge?
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
Jul 24, 2014 | Karcher WV50 Window Vacuum
Where's the serial number on the karcher WV window vacuum
Hi. I've just bought the karcher window vac wv50 & am having the same problem finding the serial No. I presume you want to register your product for the guarantee to be valid. I went online Karcher.co.uk & registered mine. You will note that when doing so it does not ask for a serial number but a model No. This is found on the side of box you got the item in (mine is just above the barcode) & it reads something like; 1.633-113.0. Hope you still have the box!
Jul 23, 2014 | Karcher WV50 Window Vacuum
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
Jun 23, 2014 | Karcher WV50 Window Vacuum
Can't switch Karcher window vac off
I had the same problem and I let the battery run down to stop it cycling on and off. My husband investigated it and found that there is a fault with the on board battery charge sensing circuit. (when the charge is about 10 to 15 % remaining the onboard ic controller cycles the unit on and off, irrespective of the switch. He checked it by cutting wires to the switch and it still cycled off and on so the switch was not faulty.
He put it all back together and said to charge it before it gets too low. If it cycles on and off it probably needs a re charge at that point.
Unfortunately there is no battery level indicator on the tool and nothing to suggest in the manual of what may happen when battery is flattening.
I am taking this up with Karcher as I only used it three times so far and it it was not a cheap gadget. Hope this helps
Mar 08, 2013 | Karcher WV50 Window Vacuum
Garden Logo
Top Karcher Garden Experts
John Trevino
Ian Summerfield
Ian Summerfield
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
