SOURCE: Anti theft activated-now car won't start and radio
to turn off the theft system, all you have to do is put the key in the door lock and lock and unlock the door, this shuts down the anti theft system,now this has nothing to do with the radio, the only way the radio would ask for the code is if it was removed or the battery unhooked,anyway try the unlocking of the door even try the passenger door, hope this helps.
SOURCE: 1997 cadillac deville delagance - anti theft device
I've got a 97 deville d'elegance that has issues similar to these. Last year the red anti-theft light came on and the car wouldn't start-took it to the dealership and they replaced the PCM? (the main brain for the system) for $900...the guy told us the wiring was so corroded he didn't want to mess with it much. Today the message started flashing on the dash that says "anti-theft problem/ car may not restart" but it still turned over in the driveway a couple times so I am hoping I can reset it. The wiring system is jacked and will probably need to replace the wiring harness completely. Doubt its worth it. Not a secure feeling with 2 babies in the back seat in the middle of winter....
SOURCE: he message is ANTI THEFT MODE IS ENABLE. When it
try to go to bios by pressing f2 on start ..and after that choose optimal factory defaults from the list ...it will be somewhere there a line named exactly like that ..after chooseing it ..press f10 to save changes..and reboot ...if it set from there it will go away..
SOURCE: The car wont start, the
TRY REPROGRAM KEY .PUT KEY IN IGNITION SWITCH TURN IGNITION SWITCH ON POSITION 20 SECONDS DONT START ENGINE WAIT 20 SECONDS TURN OFF SWITCH THEN TURN SWITCH BACK ON 20 SECONDS WATCH THE THEFT SECURITY LIGHT BLINKING.WHEN THEFT STOP BLINKING VECHICLE WILL CRANK.IF LIGHT STILL BLINKING.TRY FEW MORE TIMES KEY IN SWITCH ON POSITION FOR 20 SECONDS.MAKE SURE YOU HAVE THE CORRECT CAR KEYS IN SWITCH IF NOT WRONG SET OF CAR KEYS WILL SET OFF THEFT SECURITY SYSTEM.IF KEY RESETTING TRICK DONT WORK.CHECK BATTERY POWER MAKE SURE YOUR BATTERY HAS 12.5 VOLTS AND CHECK SECURITY THEFT FUSE.IF ALL LOOKS GOOD YOUR SECURITY HAS TO BE CHECKED OUT AT THE DEALERSHIP.
SOURCE: anti theft system -can't start car
The price is forbidding our small income expenses. . .BUT if you can
determine my explanation below that your bypass is compatible with ours?
We, I, my wife and baby, are confined in the seculed place in Hayfork
mountains. . .I am seeking for main stand-alone switcher that turns off
against fuel pump, against inner dome light, against rear trunk lid light,
against auto transmission and against four door lock actuators . . .I
successfully made it run with bypass starter relay and hot wired down to
gas tank pump and it runs well but "service immediately" light stays on..
and auto transmission starts on 3 rd gear that stalls engine, it wont start
on second gear. . .when arrived home on uphill road it wont go up so I
drove it on reverse and finally parked here. . .
I KNOW it is a few steps ahead where stand-alone switcher are. I am going
to follow the dome light's wire down to the place where relay-switchers
are. . or follow gas pump wire that I assume can be very hard way to do. .
but before I go ahead that if you can tell me where those switchers for
A/T, fuel pump,inner lights, doors are located?? in 1998 SL1 ? that would
really save my searching . . . Your tips without having to purchase your
bypassing kit would be greatly appreciated.
Sincerely, Donald
