SOURCE: LG 50la6970 no backlight i have sound and dark images!
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
If you can see an image with a flashlight and you can control the tv with the remote then the main board is not the problem. You've replaced the LED driver board, so that leaves the LED strips inside the LCD panel as the likely problem.
SOURCE: LG 47LN5750 No picture
If you have backlights its not going to be the tcon for future reference. you have some shorted or open LEDs in the panel. Check the voltage going to the LED sets, should be 100 plus volts
SOURCE: Panasonic TC-L55DT50 has no backlight. How to proceed?
You have some bad LED lamps in the panel, its not a fun job to get at them and change them but if you watch a couple vids it should give you an idea how to do it, other issue is cost as the light strips can be expensive depending on the set and its size...Good luck!!
