Backlight comes on on power up Power supply check input or source 3v ok 5v ok 24v ok 12v measures 19.1v standby and power on no obvious bulged caps on any board. Mainboard has red led on in standby Mainboard has a red and blue led on power up.
SOURCE: Have a vizio 47" vo47lfhdtv10a,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this helpout in solving the problem...
SOURCE: Olevia lt42HVi Blue led goes out when power on,
The screen fuse probley blew so you should unplig it cause there's a possibility that it could catch on fire
