SOURCE: my maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
SOURCE: The dreaded LF code
HI, there is not a defect notice or recall on this particular unit but, we get a lot of complaints about this specific issue concerning the LF code on a frequent basis. this issue dose concern the inlet valve.
The replacement will work better than the factory installed piece. This is basically a blind defect.(defective factory part).
SOURCE: whirlpool cabrio washer starts to
Try cleaning your inlet valve filters. Turn off your water supply and remove the hoses from the washer. The filter screens are located just inside of the valves. Just twist them out, clean, and reinstall.
Good luck.
SOURCE: Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
