Computers & Internet Logo
I
Intellisite Posted on Nov 30, 2018
All lines lights up cannot make a call or receive any, opticon switchboard
Is the tiny tab in the indent of the Dali Opticon 200 supposed to move when pressed? Nothing happens & blue light never stops flashing
Contact Dali direct. It is a little known make.
DALI OPTICON - DALI Speakers
www.dali-speakers.com > media > opticon-whitepaper
PDF OPTICON is a true DALI speaker with DALI manufactured parts and is assembled ... 25-200. 40 - 300. 30 - 150. 30 - 150. Crossover Frequency [Hz]. 2,000. 2,000.
We have a Telkom Business Opticon switchboard and we do not know how to change the time.
Perhaps contact Telkom for assistance. Those of us in the other part of the world don't have access to Telkom switchboards.
1helpful
Error - 8 on Opticon PHL 2700
It happened to me once. I basically reboot the opticon. and upload the data to the opticon again. and problem solved.
I have various incoming lines into my idcs28d switchboard - how do i program the switchboard to name each incoming line so that we can see the name allocated to each incoming line when the switchboard...
if you follow the the video I have posted you should be able to tag inbound DDIs, the phone used is the new 14 btn samsung handset, the soft buttons an a 12 btn handset are down the side but apart from that the softkeys are the same. go to http://www.abbeytelecom.com for more of these.
Is there a way to check the configuration of a OPTICON OPI 2201?
usually there are no settings as most computers see the barcode and crdit card scanners as keyboard/input devices. unless the manufacture has additional software and drivers the device is simply an input capture device.
Opticon OPR-3201-USB computer does not recognize scanner.
get your manual and scan in the appropriate "host" option. You will have to scan in the "USB host" barcode. There may be more than one. Your scanner should be set to the HID usb Keyboard option. Or contact the Opticon Help Desk. You can download the manual at http://office.manualsonline.com/manuals/mfg/opticon/opticon_scanner_product_list.html
Receiving fax cut off
There are some settings to check.
1 make sure the ECM mode is ON.
2. Make sure Junk Mail is OFF
3. Be sure Secure receive is OFF.
There is also an adjustment called Distinct ring that may have to be set. it is a slightly differnt set up for differing modles.
Hope this helps.
You may have a bad fax board in the machine. That is the least likely problem. Those boards are pretty reliable, but not perfect.
I must complement you on all the checks you have done. Most people will not suspect the phone line.
Well, one other thing I thought of with the Phone line. If it is a digital phone line, Xerox fax has problems with digital lines.
Those are the things I can think of.
Switchboard
Same problem no answer as of yet
Top Opticon Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Opticon Computer and Internet Expert? Answer questions, earn points and help others
