Question about Bosch Washing Machines
Where is the belt on a Bosch classic xx washing machine doesn't spin Awaiting your reply
    Top Expert:
  • Bosch Master
  • 29,343 Answers
Posted on Nov 29, 2018
6ya staff
SOURCE:
Anonymous
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
Anonymous
SOURCE: bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
Posted on Jul 23, 2009
Jarrod Matthews
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
Anonymous
  • 375 Answers
SOURCE: Bosch classic xx 5 mintues into the wash, stops and tripps elec.
Hello Sir,
I think that this is due to a faulty Main box Fuse. This usually happens when the heating elements of the washer go on. Try to inspect for faults, cracks or breakages in fuse box or in switches.
Thank you Sir,
Have a nice day.
Posted on Jan 13, 2010
Testimonial: "Mr Dhar,.Very helpful, I have got something now to go on to solve the problem. Thanks a lot. "
My Bosch maxx Classic won't spin or wash clothes
could be drive belt broken. can you hear the motor running if so it's as suggested . good luck
Oct 26, 2016 | Bosch Washing Machines
Why is my Bosch 1200 classic spin light flashing and won't machine won't spin
They aren't very complicated machines. Unplug and remove the back. Look for trapped clothing, broken belt or something that seems out of place. If it all looks normal you could have a bad circuit board (but if that's the case the machine should throw an error code) Cheap on EBay and easy to replace. Mine was $45 and took less than 10 minutes.
Jul 21, 2014 | Bosch Washing Machines
Bosch washing machine will not spin
check belt if you can still here the motor but doesent do any thing its the belt if no noise motor
Aug 24, 2012 | Bosch Washing Machines
Bosch Maxx800 Front Loader Not Spinning.
Hi, if your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Thank you.
Jun 06, 2012 | Bosch Washing Machines
Hello I've got a Bosch classic 1200 wfo246 washing
Bosch classic 1200 wfo246 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 26, 2011 | Bosch Washing Machines
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Hi we have a Bosch classic 1000 wfl2062gb. it refuses to wash or spin. the pump is clear and there is no water in machine. motor connections and belt are all ok. running out of ideas.... any suggestions...
Bosch classic 1000 wfl2062gb This video will show you how to change the pump washing machine
Dec 21, 2010 | Bosch Washing Machines
Hello Sir,
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
Jan 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Dec 09, 2009 | Bosch Washing Machines
Washing Machines Logo
52 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
