Laptop will not boot.
SOURCE: NSPIRE/ASUS LAPTOP
I'm not sure what model of laptop do you use.But I'm pretty sure that all laptop have quite similar method to replacing the hard drive. It is below the laptop and usually at the screwed panel that you'll need to open have indicate a HHD symbol. You can check out the video of how to replacing a laptop hard drive through this link : http://www.youtube.com/watch?v=cvmNHPogvWA
SOURCE: Laptop will not boot up
THis error is telling you that there's a problem with yoru laptop hard driver where the operating system is installed that's why it cannot boot, so the best thing to do here is to replace the hard drive then after that , if you have important file on that old hard drive from your laptop you can buy a hard drive enclosure and make the old hard drive a external drive and that way you should be able to retrive some of your data that is save on it.........
Hope that helps.......
SOURCE: Operating System not found PXE-E61 Media Test Failure IBM T42
Some BIOS allows for a hard drive diags. try it to test the hard drive, if ther is no such utility you need to test the hard drive anoter way.
Basically either the hard disk controller has failed or the hard drive is faulty. In most cases the hard drive is dead.
To check if the hard drive is OK, remove the hard drive and attach it to a USB hard drive adapter then plug it into a working computer's USB port. If the computer sees it as an external drive and you can view the contents of the external drive then the hard drive is OK.
SOURCE: Can my hard drive be salvaged?
You can definitely get another one, as long as it's compatible with your system...get the original specs from dell, then search online at western digital, tiger direct, etc. etc.Many online sites will have recommendations for your system.
Please consult links here and here
You may want to run chkdsk to see what's up with it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: "Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
hope this helps
