SOURCE: hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
SOURCE: digital audio out jack
That output only works with digital signals (digital tv channels and digital audio from the hdmi in jack).
The HDLCD2600 has no analog out. Sorry.
SOURCE: cerwin vega ht-10d subwoofer won't work in yamaha reciever
Actually, I had the same problem with my JBL PB10. It was the cable. I had to buy a one direction shielded rca cable. If you put it in backwards it will not work. The cable was around 75.00. But it was well worth it. The first cable I tried was a cheap sony brand sub rca cable. I ended up buying the AR(Acoustic Research) 15ft. directional subwoofer RCA cable from Best Buy. Make sure you have your receiver set to the proper setting too. If you have it hooked to main, set it to main. If you have it hooked to the L.F.E.(RCA cable) set it on L.F.E.. Some have the option to set to both. If it is a non powered sub a RCA cable will not work. You will have to run your main speaker cables to the sub first, then from the sub to the speakers. It then "piggybacks" the Low Frequency signals from the receiver.
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
