Question about Canon PIXMA MX850 Multifunction Printer
Windows says printer offline, but it is not offline. network settings confirmed. windows firewall turned off. scanner works perfectly over network, but printer is "offline"
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Canon Expert
  • 241 Answers
Elementary Solutions to Troubleshoot HP Printer Driver is unavailable in Windows 10:
There are thousands of printing issues and so are the solutions. There is no printing error without a solution along with that. So if your HP Printer becomes unresponsive after an upgrade, then here are the list solutions that you can try to erase the multifarious issues:
Solution 1: Fix HP Printer Driver Related Error
If the printer driver is not compatible with the system, you no longer be able to pass printing command. On such situation, you need to uninstall the printer and download the compatible printer driver again. Use in-built Add or Remove Programs option to make the process happen. Yet you can avail help from HP Printer Repair Service to avoid complicacy.
Solution 2: Fix HP Printer Software Related Problem after Upgrade
When you upgrade your HP Printer, you need to remove the software package present in the system. To do so,
§First you need to open Device Manager by typing it in the Start search box.
§When the Device Manager window opens up, click on View followed by choosing Show Hidden Devices.
§Make sure whether there are any entry related to HP Printer or not.
§If yes, remove the entries and disconnect the Printer.
§Restart the system to save the changes.
If You Still Get Stuck then Do Visit Us: hp printer driver unavailable windows 10
Toll-Free No: +1-888-633-7151
Posted on Aug 16, 2019
    New Friend:
    New Friend:
    Problem Solver:
  • 15 Answers
Pretty good post. I found your website perfect for my needs cool math games
Posted on Jan 25, 2019
    Master:
  • Canon Master
  • 317 Answers
Go to the printer's setup
Turn the printer on and press the "setup" button. On the printer's operational panel select "Wireless LAN Setup" and press "Ok."
Select setup type
Select "Easy Setup" from the available setup options and press "OK."
Enter network information
Select the network name from the access point options and click "OK." Enter the password for the Wi-Fi network selected within the operational panel and click "OK."
Run the CD installation
Insert the setup CD into the computer and click "Run Msetup4.exe" and click "Next." Follow the on-screen prompts, such as selecting the place of residence, country or region and then click "Easy Install."
For full information please visit here: https://fixingblog.com/setup-canon-printer-wireless-network
Posted on Aug 29, 2018
    New Friend:
  • 20 Answers
The printer offline error mostly troubles windows 7/8/10 users, The printers loses connectivity even when it is connected and operating. The status message displays offline on the computer, and the printer does not print. An Offline status indicates that the computer has failed to communicate with the printer. In some network conditions, the printer might get offline unexpectedly.
Before going to the solution for this you must know when and why printer offline error takes place:
The error may appear when Windows 8 diagnoses that the printer is unavailable, but unfortunately, most times it fails to tell whether the printer is really offline or if it has connectivity problems or printing errors. Reasons why your printer appears to be offline, include problems with hardware, such as disconnected cables or malfunctioning equipment, and problems with software, such as corrupted or incompatible driver files.
These might occur when:
1. The connection between the computer and the printer is slow/unresponsive.
2. The printer has encountered an internal error
3. There are multiple unfinished print jobs in the queue.
There are some simple steps you can follow before going to any complicated way:
Your printer offline can be a problem with the driver software. This is a small piece of code that Windows and the printers use to "talk" to each other. If the driver software is outdated, corrupted or incompatible with the version of Windows that you have installed, you may need to update it.
Restart the printer and the computer or unplug its USB cable.
Do check that the printer's power cable is plugged into an electrical outlet. If the printer is connected to a power strip, make sure the strip itself is connected to the electricity supply and is turned on.
In case you are using a network printer both wired or wireless, You restart the router as it may cause due to network failure.
Different manufacturers come with their own diagnostics software which can inform the user about the problems coming up (Ex : HP's Print and Scan Doctor), Use it as it will be really useful.
PRINTER OFFLINE ERROR Solution 1 :
Type in Services in your windows searches and hit the enter key. Click on Services option from the set of search results as shown below.
A new window for Services opens up. Scroll down and find the entry named Print Spooler.
Now right-click on Print Spooler entry and then on Properties option.
Set Startup type as Automatic from the drop-down menu.
As next, hit the Start button and wait till windows start the Print Spooler. Once done, hit Apply button.
Now if you look at the status of the Print Spooler, you can see that it is Started.
Solution 2 :
If the above method doesn't work for you, you can always try our second method. For that, type in Devices to the windows search and choose Devices and Printers from the search results.
Now find the printer that is offline and right click on it. Click on the option See what's printing from the context menu that appears.
A new window opens. Now click on the Printer tab and uncheck the option that says Use Printer Offline.
Posted on Jul 27, 2016
  • Anonymous Aug 20, 2017
    This is a persistent and aggravating bug with Canon's MG2922 and probably other printers in the MG series. The Canon drivers apparently become stuck on certain (unknown) settings that you can't see and can't change. Sometimes this will happen to only one of your computers, but not the other(s). No clue why. All you see are the seemingly-contradictory results: Printer is connected but offline, and stays offline even after uninstalling and reinstalling the drivers and other Canon software (IJ Network Tools for example). What worked for me, after trying nearly everything else I could think of, was to take the nuclear option and delete anything Canon related from the registry. Then rebooted, reinitialized the printer, reinstalled the driver, and finally the port name and IP address were back in sync, and Wi-Fi printing using Access Mode worked from both of my computers. PS - You and I are responding more than 7 years after the OP's original post (Aug 2009). Amazing that Canon hasn't fixed this pernicious bug after all of this time.
SOURCE:
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
My brother DCP-J140W won't scan. It keeps saying check connection but it is printing okay. Please help!
How is the all-in-one connected to your computer? The problem usually means that you do not have bi-directional communication between the printer and the computer.
If it is connected to your wireless network, did you ensure that the firewall allows the communication? (Some firewalls will automatically add the correct ports to the allowed list during the install of the full software.) For other firewall software or the less-complete install of the software drivers, you need to make sure that the port, 54925 , are allowed to access your computer for inbound and outbound network data. If adding that port is insufficient to allow scans to have bi-directional communication with the printer, also add port 137 (inbound and outbound). Since this step depends on your firewall, please add a comment with the firewall software on your computer. This is in the note in the Scanning section of the Brother Software User's manual for the DCP-J140W on page 35. This manual is available here: http://download.brother.com/welcome/doc002923/dcp140w_use_soft.pdf . An example of setting the Firewall rules for the Windows Firewall is shown starting on page 85 of the manual.
If your computer is connected to the printer via a USB cable, try a different (possibly shorter 6' or less) USB cable or a different port. If you have the printer connected to a USB hub, skip the hub and directly connect to the computer. Check if other devices work at the USB ports. Sometimes ports do fail; either they can't maintain the needed voltage or they don't keep the cable and pins properly aligned.
I hope this helps.
(I have seen the communication issues with stand-alone scanners as well. I saved a perfectly good scanner from the trash when the user failed to check if the scanner worked with other ports.)
Dec 16, 2013 | Brother DCP-J140w Wireless Compact Inkjet...
How to turn off firewall in windows 7 and let norton firewall work
  1. Open Windows Firewall by clicking the Start button, clicking Control Panel, clicking Security, and then clicking Windows Firewall.
  2. Click Turn Windows Firewall on or off. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click Off (not recommended), and then click OK
    Make certain that your Norton Firewall is on before you turn off windows firewall (or shortly after) Turning off Windows Firewall might make your computer (and your network, if you have one) more vulnerable to damage from worms or hackers.
    Hope this helps!
Sep 24, 2011 | Computers & Internet
Printer is offline. how do I get it online?
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online. Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Feb 28, 2011 | HP Office Equipment & Supplies
Error 36851: No response from scanner" ricoh
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Scanner error in HP officejet Pro L7590
These instructions will fix the majority of scanner problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers.
May 14, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
MY PRINTER OFFLINE
I don't have a solution for this problem. I have a comment. I have the same types of issues with my HP. I hate HP. Why is it that we can design software to remotely fly fighter jets but we can't get reliable software to print wirelessly? I am now going to throw my HP Photosmart C4580 All-in-One in the road.
Aug 29, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer online then offline
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Mar 01, 2008 | Brother MFC 420CN All-In-One InkJet...
Pixma mp600r scanning setup
Try turning off the windows firewall.
If that works, then add the Canon scanner app to the list of applications that are allowed through the firewall, then turn the firewall back on again.
Jan 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MX850 Multifunction Printer Logo
66,311 people viewed this question
Clive
Clive
old marine
old marine
Ekse
