Http://www.antiquetractorpullguide.com/wp-content/uploads/2012/01/Podium-Newsletter-27-Jan12.pdf
Recommend you purchase a manual, or join an antique tractor forum, or learn how to dig into the antique forums and glean the information.
https://www.ebay.com/itm/SERVICE-PARTS-MANUAL-SET-FOR-JOHN-DEERE-A-AW-AH-AN-AR-AO-TRACTOR-CATALOG-SHOP/392093149871?hash=item5b4a92aaaf:g:SiEAAOSwqxZbYht9:sc:USPSPriority!43015!US!-1:rk:1:pf:0
SOURCE: need a diagram of the firing order for 1972 datsun 510
Turn your crank pulley and line the timing marks to top dead center,pull the distribuor cap and see where the rotor points to, thats where the #1 position is located.
SOURCE: belt route diagram for john deere sabre 1742
Go to this site and list your model and download an operators manual. You will need the decal model number!
http://www.deere.com/en_US/ProductCatalog/HO/servlet/servlet/com.deere.u90785.cce.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&orderBy=pubType&tM=HO&searchCriteria=Belt+routing+diagram+for+Sabre+1742&submit=Search&language=english
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
SOURCE: firing order for 1998 chevy blazer 4.3L motor
For the 1998 Chevy Blazer 4.3L V6:
Firing Order:
1-6-5-4-3-2
Cylinders:
......(back)......
|..6..|.......|..5..|
|..4..|.......|..3..|
|..2..|.......|..1..|
......(front)
Distributor Connections:
...........(back)
Coil-> o
6-----> o.......o <-----5
4-----> o.......o <-----1
2-----> o.......o <-----3
...........(front)
Let me now if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
