that error is th e drum failure but replacing the toner will sort your machinethat error is th e drum failure but replacing the toner will sort your machine
You can't post conmments that contain an email address.
Re: I am looking for info on Xerox error code 010-914
It is because of drum failure, especially caused by communication, better to reinstall window and install your driver. It will erase all unnecessary file from the cache.
Belt Failure turn the mach. off and un plug for 20 to 30 seconds then turn back on if this dosent sole you need to call a tech to replace the main belt
Xeroxhttps://www.support.xerox.com > en-us > article
Jan 19, 2021 - Resolve the Duplicate IP Address Conflict With Another Device on the Network. Manually Set a Static (Permanent) IP Address on the Embedded ...
Copytechnethttps://www.copytechnet.com > ... > Xerox
Aug 30, 2014 - This error code means your bustled Fiery or Creo network controller do not communicate with the machine. Check all cable from net controller to ...
Printcopy.infohttps://printcopy.info > code=027-452
Code: 027-452; Description: IPv4 Duplicate Duplicate IPv4 addresses detected upon startup. Causes: Remedy: 1 At the printer's Control Panel, press the Menu ...
https://printcopy.info > model=Phaser+7100
A differential circuit output error was detected between the detection output and the compensation output of the Fuser Unit NC Sensor.
This error code could indicate an issue with the drum or fuser. Ensure that the toner cartridge/drum has been seated correctly, and if necessary contact a qualified technician or Xerox support to further investigate and resolve the issue.
Turn off the printer and the system then remove the cables that made the connection in between them.
Open the upper cover and remove the printer cartridges.
Clean the cartridges clearly and make sure no dust or extra material should be there inside the printer.
Make connections once again then turn on the device and print a test page.
If the issue is not resolved then chat with our expert https://printercustomerservice.org/xerox-support
016-433 on c405
Just contact your Xerox supplier Manager person who you brought the kit off and ask for an 'activation code' and enter it under the 'detail' tab in 'Supplies' > 'Supplies Plan'
